st mc workbench PMSM Motor control code generation and java related issue
NMish.1
Hello Team,
I am using st mc workbench to create a code for PMSM Motor control but when I am trying to generate the code then I got some java related issue and even I have already updated java version are present
4 REPLIES 4
Laurent Ca...
Lead II
Dear @NMish.1​
I move your text from title to description.
Best regards
Laurent Ca...
Laurent Ca...
Lead II
Dear @NMish.1​
Did you check that old java version are not remaining on your system after update?
Did you try to re-install or update STM32CubeMX tool version?
Best regards
Laurent Ca...
Laurent Ca...
Lead II
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
Laurent Ca...
SE D.1
Same issue here also,
Could you please tell the solution?
