STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1400 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 555 Views
  • 0 replies
STM32CubeIDE USB Host FS (1.5MBit/s) HID - Mini keyboard Touchpad Wireless is stopping responding when it enters standby or touchpad mode
Does anyone know how to make this keyboard work?With the MAX3421E chip in conjunction with the USH30 library this works but with STM32CubeIDE not working properly.https://www.amazon.com/Rii-Wireless-Keyboard-Touchpad%EF%BC%86QWERTY-Raspberry/dp/B00B9...
by Not applicable
  • 3899 Views
  • 11 replies
"Breakpoint installation failed: unmatched quote" at CubeIDE
Hi, I’ve a problem trying to setup breakpoints. At any code line where I try to setup a breakpoint, it does not matter which, neither if it’s the main.c or a library, it just keeps telling me “Breakpoint installation failed: unmatched quote�? as you ...
Fèlix by Associate II
  • 2476 Views
How to fix stm32Cube_fw_f4_V1240.zip not installing correctly
I've tried 10 or more times now to get around this problem.I'm choosing the STM32F413RGtx for the uC in STM32CubeIDE new STM32 project,I go to generate code from the embedded CubeMX screen and it always tries to download that stm32cube_fw_f4_v1240.zi...
FStra.9 by Associate III
  • 5093 Views
  • 11 replies
X CUBE AWS STM32 Discovery kit - IoT node
Hello, I'm trying to compile the firmware to use the B-L475E-IOT01A in AWS IoT.I just download the pack X CUBE AWS, import to STM32CubeIDE(v1.0.0 and v1.1.0) and compile.There are two error on make file.I try to make the samething with SW4STM32(v2.9 ...
lenonrt by Associate III
  • 1281 Views
Cube IDE Compiler error2
Hi,I'm trying to compile one of AWS project for L475 IoT and I have the silly error: make[1]: *** [vendors/st/stm32l475_discovery/BSP/B-L475E-IOT01/subdir.mk:39: vendors/st/stm32l475_discovery/BSP/B-L475E-IOT01/stm32l475e_iot01.o] Error 2   make: ***...
Tytan28 by Associate
  • 2105 Views
  • 3 replies
