STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1429 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 560 Views
  • 0 replies
Is STM32CubeIDE a tool chain? If so why does everyone including STM recommend some other tool chain in their tutorials? Can anyone recommend a good tutorial or other training source for STM32 programming?
I am in the steepest part of the learning curve for C programming and am experiencing typical frustrations. I can't get "Hello World" to run at this point. I appreciate your patience. I have just ordered the Ritchie Kerighan book and another on STM32...
SGill.1 by Associate II
  • 2568 Views
  • 5 replies
Resolved! CMSIS RTOS V1 Semaphore issues in STM32CubeIDE
Hi,I am using STM32F405, CMSIS RTOS V1, and STM32CubeIDE. I want to create a timer interrupt that periodically release the semaphore to signal the execution of a task. The issue is that it gets stuck after osSemaphoreRelease is called in the interrup...
DLim.16 by Associate II
  • 4114 Views
  • 4 replies
Missing firmware packages - can't create a project
Fresh installation, when I try to create a STM32 project a zip file with firmware is downloaded and unpacked, but I still get this error message:"Code generation could not be done because necessary firmware package is missing. Not able to complete ST...
KOlsz.1 by Associate II
  • 4484 Views
  • 3 replies
Unable to update software packs
Hi,I am unable to update embedded software packages.To update I select "Manage embedded software packages" menu item. Packages manager window opens. I see "Check Firmware & Software. Download File updaters.zip" but progress bar stays at 0 bytes. Afte...
Dmitri by Associate II
  • 2223 Views
  • 3 replies
Resolved! How do I uninstall STM32CubeIDE from macOS?
I would like to remove STM32CubeIDE (v1.2.0) from my Mac (os 10.14.6).Removing the IDE is straightforward, just drag the .app to the trash. But how do I remove the ST Link Server from my machine? The ST Link Server Installer doesn't specify where it ...
BFrau.1 by Associate
  • 4736 Views
  • 2 kudos
Bug in the debugger?
Not sure whether this is a GDB or Eclipse behavior, or "feature" of debug info created by gcc compiler...Debugger in CubeIDE and Atollic refuses to display pointers to volatile.For example: volatile char *ptr = some_func();It always says that such po...
Pavel A. by Super User
  • 2798 Views
  • 5 replies
