STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1690 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 633 Views
  • 0 replies
Resolved! Using SPI / HAL - Where to start?
Hey, mechatronics student here. So ive been trying to make the transition from Arduino to STM32 lately, and am a little overwhelmed by hardware-oriented programming.So I can get things like Blink running, and know my way around C good enough to have ...
JGiem.1 by Associate III
  • 3076 Views
  • 2 kudos
How to get last address loaded, or size, from .ld file?
A live CAN loader resides in the first 0x8000 in a STM32L431RB. I want to do a CRC check on the application that loads, following the loader, e.g. 0x08008000. The goal is for the loader to run a CRC check upon reset and jump to the app if the CRC is ...
DHase.1 by Associate III
  • 4925 Views
  • 4 replies
Project Explorer icons - what does slash mean?
I have the FWupgrade_Standalone example loaded, looks like files marked with slash and dimmed are part of the example, so should be active files - so what does the CM7 directory icons mean?
'SMike by Associate III
  • 4424 Views
  • 7 replies
Resolved! Where should I initialise Git when creating a CubeIDE project?
Hi, This may be more of a general Git usage question, but I am currently learning how to use Git so I can begin to implement version control with my projects. There doesn't seem to be many examples online of embedded use, it's mostly web stuff. I use...
CDyer.1 by Senior
  • 4922 Views
  • 6 replies
  • 1 kudos
SWV ITM stopped working (2 boards)
Hello,It worked for about a year or two but was found to not work when trying it after some weeks. I have checked the obvious items:Enabled in Project properties DebugI am using the standard codealthough, on a breakpoint there, that value should not ...
PHolt.1 by Senior III
  • 1832 Views
  • 3 replies
  • 1 kudos
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
