STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 221 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4066 Views
  • 0 replies
  • 3 kudos
Set Up Communication Between ESP8266-01 and NUCLEO-F030R8
I've been tasked with figuring out how to get a mobile app to communicate with an MCU then in turn control a stepper motor. Right now I'm trying to get the WiFi module (ESP8266-01) and MCU (NUCLEO-F030R8) to play nice with each other. The catch is I ...
SNeub by Associate II
  • 1213 Views
  • 0 replies
Resolved! Failed to read memory after RDP set/reset
I'm trying to program BLE stack on a custom board based on STM32WB55CG. I'm using SWD, CubeProgrammer 2.2, CubeFW_WB 1.1.1.First I've successfully performed -fwdelete. But then I got "Firmware not authentic" error trying to make -fwupgrade. So I've s...
Stecklo by Senior
  • 3061 Views
STM32F411 and P-NUCLEO-LRWAN1 (SX1272MB2DAS)
Hi,I'm trying to run ping pong example in f411 board with sx12mb2das module but it doens't work and I don't know why (I have b-l072z-lrwan running as receptor). Has anybody ran the program in that board?Thank you.
Larraitz by Associate II
  • 2106 Views
  • 4 replies
Recieve only txdone, onrxtimeout,ontxdone
Hi. I have a brand new STM32 LORA and SIgfox discovery kit. I try to send any AT-command but i Only/always recieve txdone, onrxtimeout,ontxdone what is wrong???Best regardsBjarne
BToft by Associate II
  • 795 Views
  • 0 replies
Problems in debug I-CUBE_LRWAN in PINGPONG MODE.
Hello everyone, I am debugging my stm32L073+sx1272 in the pingpong mode. I run the program in debug mode. I know that there is a while loop and the "state" variable should be the variable to implement different functions such as TX RX RX_TIMEOUT and ...
mlau.18 by Associate II
  • 972 Views
  • 1 replies
