Issue regarding "generate peripheral initialization as a pair of '.c/.h' files per peripheral" using stm32wb55
‎2022-06-06 8:13 PM
After enabling "generate peripheral initialization as a pair of '.c/.h' files per peripheral" under Project manager > Code generator > Generated files, everything stops working, including debugging log also does not show up in my tera term.
How to regenerate this problem: (stm32wb55 )
- Select the BLE_Custom example from the library
- Add FreeRTOS in the ioc. file (Remember to set the TOTAL_HEAP_SIZE to 20480, Enable USE_NEWLIB_REENTRANT , change your SYS timebase source to TIM17)
- Go to Project manager > Code generator > Generated files
- Enable "generate peripheral initialization as a pair of '.c/.h' files per peripheral"
* There will be no issue if I did not enable the "generate peripheral initialization as a pair of '.c/.h' files per peripheral" but I feel that it is messy if I don't enable it.
- Labels:
BLE
STM32CubeMX
STM32WB series
‎2022-06-23 6:30 AM
Hello @Nicholas​
First let me thank you for having reported :smiling_face_with_smiling_eyes:
Actually you're right, I've been able to reproduce the same misbehavior from my side when using the same configuration as you.
I also tested the same setup but while disabling the "generate peripheral initialization as a pair of '.c/.h' files per peripheral" option, and it did worked fine.
I compared the generated code for both setting and I found that when the "generate peripheral initialization as a pair of '.c/.h' files per peripheral" option is enabled the "MX_APPE_Init();" is not generated which cause the problem.
When the "MX_APPE_Init();" is added just before "osKernelStart();" the project should run correctly.
With this being said, this problem is raised internally to be reviewed. I'll keep you posted with the updates.
Internal ticket number: 130851 (This is an internal tracking number and is not accessible or usable by customers).
Thanks for your contribution.
Semer.
‎2022-06-23 6:30 AM
Hello @Nicholas​
Semer.
‎2022-11-29 6:19 AM
Hello @Nicholas​
The issue is fixed with the STM32CubeMx 6.7.0 available under this link.
Semer.
