STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 234 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4076 Views
  • 0 replies
  • 3 kudos
not entering stop mode - STM32WB55
I understand that C2 manages the power state automatically. I have confirmed this using the Cube power monitor utility, seeing that when there's no RF activity power draw on an the st32wb55 nucleo eval kit falls below 3uA. This was done with a simple...
rudivs by Associate
  • 1782 Views
  • 1 replies
  • 1 kudos
Is it possible to seperately use RTC with BLE?
Board: STM32WB55Software: RTC and BLEHello,I am trying to get a project set up on the above board. It needs BLE, USB and RTC seperately. I have the USB running with Bluetooth now thanks to a relatively recent post offering a means to fix the incompat...
USB dongle BLE STM32WB55
I have a problem with STM32WB55 USB dongle Nucleo. After adding some code (according to: AN5289 Building wireless applications with STM32WB series MCUs, https://stcommunity.st.com/t5/stm32-mcus/how-to-run-a-ble-p2p-server-simultaneously-with-usb-cdc-...
Resolved! STM32WB55 p2p router
Hello! Is it possible to connect stm32wb55 dongle to multiple servers without using a smartphone app???so i can get data from servers and see it on terminal over usb , like Realterm???
aicha by Associate II
  • 1677 Views
  • 1 replies
  • 1 kudos
Resolved! BLE
Can i connect stm32wb55 dongle as a central to different ble servers simultaniously and how to do it ?
  • 2672 Views
  • 4 replies
  • 1 kudos
STM32WB AT commands
Hello,I want to configure the STM32WB1x using AT commands. I tried sending just "AT" to see if it works with the pre-flashed firmware, but I received no response. I checked the firmware flashed on the chip, which is STM32wb1x_BLE_Stack_full_fw.bin, a...
abach by Associate II
  • 3807 Views
  • 5 replies
Resolved! Error in Datasheet of STM32WB10
Hi,I just found an error in the data sheet and wanted to let you guys know. Don´t know who else to contact.Kind regardsRené
RWeil.2 by Associate III
  • 3405 Views
  • 4 replies
