STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
Invalidate redraw part even if not visible
I am facing performance issue due probably to my way for invalidation on data update. I have widget inside container that are not visible. When I have a data change, I update the content of the widget and invalidate the textarea for example. But this...
SBACO by Associate III
  • 1015 Views
  • 0 replies
Resolved! STM32U585 DCMI+DMA problem
Hello, I am facing problems with DMA and DCMI . Since DMA has ability to generate multiple block transfers with single configuration, it means i can transfer image larger that 0xFFFF.So I writen code that would repat my DMA transfer for as much line ...
Linas L by Senior II
  • 8231 Views
Drawables
Hi, I created a list and I need set visible image when element of the list is clickedBut problem is that others drawables does not unselected when pressed one of the list elements. When I click on list element I call this functionvoid AddZone::ZoneSe...
heyo by Senior
  • 1362 Views
