STM32 MCUs Motor control
Discuss STM32 solutions for motor control, including PID tuning, sensorless operation, ADC noise, custom algorithms, and more.
User Manual MCSDK documentation
  Dear MCSDK users, The full MCSDK documentation is embedded in the Motor Control Workbench tool. Refer to Workbench tool > About > Documentations > Documentation.This document provides: Introduction: Includes startup guide links for MCSDK, HSO featu...
GMA by ST Employee
  • 1662 Views
  • 0 replies
MCSDK 6.4.0 is out!
Dear MCSDK users, MCSDK version 6.4.0 is now available: Download It here. This version of the new Motor Control SDK 6 series (X-CUBE-MCDSK) provides mainly FOC and 6Step improvements, here are the main changes for this version: Motor Control Features...
GMA by ST Employee
  • 4803 Views
  • 0 replies
  • 3 kudos
Board Manager documentation is out !
The documentation of the Board descriptions format is now available on Motor Control Boards Description Wiki page, this documentation is compatible with MCSDK versions from 6.1.2. Board Descriptions are used by the ST motor-control workbench to enabl...
Zied b. by ST Employee
  • 9511 Views
  • 5 replies
  • 3 kudos
Resolved! Why ST does not provide a support?
Look at this forum! Almost no one is getting answers for their questions from ST!I have received one answer from ST only. I guess I am lucky. Thank you. I asked 3 more questions - no luck.I have opened the case with online support, It was "escalated"...
EShaw.1 by Associate II
  • 2337 Views
  • 6 replies
Resolved! Details of SPD_GetAvrgMecSpeedUnit
I asked a question before on the routine SPD_GetAvrgMecSpeedUnit but the answers did not address what I was looking for. https://community.st.com/s/question/0D53W00000xsTlzSAE/information-on-the-c-code-procedure-spdgetavrgmecspeedunit-This routine re...
BTrem.1 by Senior II
  • 2623 Views
  • 3 replies
USART3 stops working after code update.
I have a motor control board built around the STM32F446RET6. I was updating code using motor control workbench to alter the control parameters.After an update, I was no longer able to use the motor control workbench console to communicate with the bo...
DTard.1 by Associate II
  • 5970 Views
  • 12 replies
Resolved! STEVAL-SPIN3202 Correct positions of the jumpers
Dear ST,Could you please advice on the correct positions of STEVAL-SPIN3202 jumpers to run an example with ST MotorPilot.J9 - BOOT0 Open or closed? J7 - RX - TX Open or closed, Could you please explain why would we need to connect RX and TX? Which o...
  • 1705 Views
Deadtime
First thingI am trying to XOR, 3 pwm's and If the xor output is 1 "motor is on" otherwise "motor is off".I am getting 90ns deadtime. I mean between the pwm's there is some gap. How to encounter this situation? ( I wnt to use a gpio and Im using a nuc...
Vmere.1 by Senior
  • 1122 Views
  • 0 replies
MC workbench with bldc using hall sensors.
Hi, I am fairly new to motor control and ST software. I am trying to setup a bldc hall sensor motor with the MC workbench tool to control speed for now. I am using the b-g431b-esc1 discovery kit. I have wired the motor to the kit as described in um25...
How to run a BLDC using C-functions of mc_api.c
I tried to run a motor(BLDC).But, my motor doesn't run. I refered to this PDF to page 45~.https://www.st.com/content/ccc/resource/technical/document/user_manual/group1/48/e6/91/f4/66/ea/48/a1/DM00490980/files/DM00490980.pdf/jcr:content/translations/e...
smiya.1 by Associate
  • 2155 Views
  • 3 replies
