STM32 MCUs Embedded software
Resolved! http client lwip stm32h745-DISCO
Hello!I need to implement a task in FreeRTOS for my project that makes GET, POST, and PATCH requests to a server. So far, I have managed to send a UDP message to a specific port on a PC thanks to the following post:https://community.st.com/t5/stm32-m...
RafaelS by Associate III
  • 3151 Views
  • 5 replies
  • 1 kudos
Resolved! HAL_UART_Receive_IT is not working
Originally a reply in this thread - split as a separate question.Hello My blocking mode is working with "HAL_UART_Receive(&huart4, temp, 1, 100);"Nonblocking mode is not workingCan you suggest anything to check?I have defined as said /* USER CODE BEG...
Failed to execute MI command - load .elf file
I have been using a NUCLEO-F413 board to try and understand how to program to user FLASH using the example code in the STMicro repository and STM32Cube to program. However when I now try and program the board I get the below error: Has me trying to w...
GTann.1 by Associate III
  • 3912 Views
  • 8 replies
  • 1 kudos
