STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1433 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 560 Views
  • 0 replies
CubeIDE checking for updated files on Mac
When I start a new project it constantly checks for updates. A post in May said to uncheck CubeIDE in available software sites. I unchecked CubeIDE and restarted it, but I still get the same problem.
EGJ39 by Associate
  • 869 Views
  • 0 replies
Hello everyone, have been using chip STM32f105rc and I am not able to access input/ output ports? Help? Thanks in advance.
In this above situation I am using STM32f105rc microcontroller and uploading code using SWD(Serial Wire Debugger). When I am using utility it gets scanned but when I am trying to upload code from cube ide then It doesn't go on. I don't what settings ...
KSing by Associate II
  • 2396 Views
What causes the strange behavior in SWO Data Trace/ ITM?
I am trying to gain some confidence using the SWO debug methodsbut I experienced some strange beavior what I cannot explain.1. I tried to send a 32 bit value though ITMPort1 in an inifiteloop and it works awhile but sometimes it switches to ITMPort21...
NCTUser by Associate III
  • 2131 Views
  • 0 replies
  • 1 kudos
Gcc optimization problem
I have a problem in STM32CubeIDE.​unsigned char readKey (void) { volatile unsigned char keyValue=HAL_GPIO_ReadPin (KEY_GPIO_Port, KEY_Pin); if (0 == keyValue) { printf ("before delay\r\n"); HAL_Delay (10); keyValue=HAL_GPIO_ReadPin (KEY_GPIO...
User.151 by Associate
  • 1476 Views
How to Set Code Auto-Completion?
:sad_but_relieved_face: It`s my first time to use tools like STM32CubeIDE ( keil v5 before :) ). I want to know where can i set Code Auto-Completion or CODE-TIPS ?Thanks!
hbowe by Associate II
  • 6019 Views
  • 3 replies
  • 4 kudos
Debug error
SEGGER J-Link GDB Server V6.44c Command Line Version​JLinkARM.dll V6.44c (DLL compiled Mar 22 2019 17:26:40)​Command line: -port 2331 -s -device STM32F042F4 -endian little -speed 1000 -vd-----GDB Server start settings-----GDBInit file:         noneGD...
  • 1371 Views
  • 1 replies
  • 1 kudos
