STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1443 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 565 Views
  • 0 replies
Garbled Font in the title of the IDE window
As shown in the figure, the title of the window bar seems to have become garbled, even though its content was originally in English. I thought it was due to the software defaulting to a font that only supports Western characters, but changing all the...
Altboy23 by Associate
  • 503 Views
  • 1 replies
STM32H755 dual core SWO printf
Hi,I would like to get printf() debug messages from both M7 and M4 core using SWO pin. It seems to work as expected on M7 core, but I cannot get it work on M4. Ideally, I would like to have messages from both cores in parallel, but it would be great ...
mosamasa by Associate II
  • 383 Views
  • 1 replies
STM32CubeIDE hangs at “Performing pre-launch check”
 I'm experiencing an issue when attempting to debug a project in STM32CubeIDE v1.19.0 using a NUCLEO-H753ZI board and ST-LINK V3 (FW: V3J16M9). The debugger appears to hang during the early initialization phase and fails to proceed with device enumer...
bugiii by Associate II
  • 1904 Views
  • 6 replies
  • 1 kudos
Live Expression Shows Incorrect Data
I encountered a significant problem with the live expressions during debugging, as the variables displayed erratic values and symbols when they were set as unsigned. I spent several days trying to verify this, as I previously had doubts about my code...
Cube IDE 1.19.0 Login Failed
The login via HELP->STM32Cube Updates->Connection to myST   does not seem to be working properly. Trying to login I first get a small splash window with a button which I can press which opens a webview(?) which sometimes displays an "Accept Cookie" d...
a2800276 by Associate
  • 560 Views
C++ support of stm32cubeide does not work.
in default situation, you could not call c++ function in C file.  So the main.c  is not suitable file in C++ project.   if user choose C++ project,the generated main.c ,stm32h7xx_it.c should sufixed with .cpp.
yujin by Associate II
  • 2398 Views
  • 8 replies
  • 9 kudos
Resolved! Build error
Hi, I tried to build my project but I faced these errors :--------------------------------------------------------------------------------------------------------------------------------------------------C:/ST/STM32CubeIDE_1.12.1/STM32CubeIDE/plugins...
Gnahore by Senior
  • 25730 Views
  • 11 replies
  • 2 kudos
