STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1400 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 554 Views
  • 0 replies
stm32 cubeide: How to modify C language parallel compilation
How to configure parallel compilation in cubeide, that is, "j-4" "j-8" and I encountered an error in the Windows 87 code, how to solve it, I changed the path and still couldn't do it····································································...
CubeIde 2.1.0 Error with J-link
Hello,I have been using CubeIDE for some time to flash the STM32H755ZIT6 microcontroller with the J-Link Base. After the latest update, I started getting this error: Error in final launch sequence:Failed to execute MI command:target remote localhost:...
Debugger steps and runs slowly
I started learning embedded systems recently, and have been using the Nucleo-F303RE board with the STM32CubeIDE toolchain. Recently, I compiled a program and started stepping through it in the debugger. Everything worked fine as always. I started to ...
User authentication service maintenance on 12 March
Please note that the user authentication service will be under maintenance on 12 March at 5:30 AM CET (10:00 AM IST) for approximately one hour. During this period, some disruptions may occur. The impact is limited to versions earlier than STM32CubeM...
  • 158 Views
  • 0 replies
Resolved! Error during saving assembler source files
There is a problem with saving assembler source files when the C/C++ > Editor > Save Action > Format source code option is enabled:As a result, the file is not saved, and when it is just created, there is no file at all. It's quite irritating, especi...
Cant download STM32CubeIDE
I’ve been trying to download STM32CubeIDE from your website for the past 3 days without any luck. I’m located in Norway. I recently updated my old installation (version 1.4.x, not sure exactly which), and something went wrong during the update. Now t...
oliloken by Associate
  • 261 Views
