STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 202 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4046 Views
  • 0 replies
  • 3 kudos
STM32 Nucleo network and wireless shields
Posted on June 23, 2014 at 12:01Dear all, Do you know whether ST provides network (RJ-45) and wireless shields (a/b/g communication) for the new Nucleo F401-RE / F411-RE platforms. I know these platforms are compatible with: Arduino Uno Revision 3...
jmpoure by Associate
  • 1159 Views
  • 1 replies
UM0794: GSM interface
Posted on September 24, 2011 at 01:45I read previous threads about source code. But how can i find source code related with UM0794: GSM interface?... Is there any link ? Should we contact local distributor for this? if it is so, why ? Thanks in adva...
irmakci by Associate II
  • 2622 Views
  • 7 replies
STM32F4 Wifi
Posted on March 18, 2013 at 05:29Hi All, Im after adding WiFi capabilities to my PCB (either onboard chip or shield) for the STM32F4. Basically the unit will need to connect to a network via DHCP and dump data from an SD card to the server. I'm usin...
