STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 228 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4071 Views
  • 0 replies
  • 3 kudos
Resolved! How to use the On/Off Router example with ZigBee2MQTT?
Hi,I want to learn ZigBee and for this, I want to see what´s going on in the On/Off Router example and build up an environment to test my own implementations by using ZigBee2MQTT and a CC2531 dongle. I flashed the example onto my STM32WB55 Nucleo and...
Kampi by Associate III
  • 2859 Views
  • 1 kudos
STM32WL55: Subghz RADIO_GET_STATUS returns invalid data.
Hi, i'm currently working on a Project where i need to send some data via LoRa.I've been struggeling to get a transmission going, so i decided to check the basics.To test the radio, i went ahead and rebuilt the SUBGHZ_Tx_Mode example from the STMCube...
D.Heink by Associate III
  • 2000 Views
  • 1 replies
Resolved! Lorawan stack Class B support
Does current Lorawan library implementation fully support Class B? In changelog for lorawan libraries inside CubeWL in latest version 4.6.0 we found new functionalities being added. Are there any functionalities still missing in Class B?
Kamil_P by Associate
  • 1289 Views
  • 1 replies
About STM32WLE4C8 demo board (MB1789-HP) question
Recently, I studied STM32WL series and want to design board by myself, so I reference MB1789-HP files to design. I have some questions about sch and pcb files, I know MCU pin 21 (RFI_N) is connect to C30 capacitor, but in PCB file, MCU pin 20 and pin...
CY_Tsai by Associate III
  • 3420 Views
  • 4 replies
Where is the list of Req_opcodes for Gatt_Error event
Hello I am getting: error on opcode 0x08 what is it?Opcodes not listed in document. See here:Table 433. ACI_GATT_ERROR_RESP_EVENT parametersParameter Size Description Possible valuesConnection_Handle 2Specifies the ATT bearer towhom the command appli...
DS.4 by Senior II
  • 1784 Views
  • 1 replies
