STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 219 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4065 Views
  • 0 replies
  • 3 kudos
Resolved! LoRa p2p communication using stm32wle5ccu6
Hi everyone,I’m trying to implement LoRa point-to-point (P2P) communication using the stm32wle5ccu6.I configured the .ioc file based on the SUBGHz_Phy PingPong example for the NUCLEO-WL55JC1. Then, I wrote the code for LoRa transmission. On the recei...
hashara by Associate
  • 1872 Views
  • 1 replies
  • 1 kudos
Resolved! Zigbee application for thermostats
Hello, i am looking into doing wireless thermostats using Zigbee who communicates with controlers. The controlers activate and desactivate valves to heat the house. What would be the configuration of the microcontrolers and how can i program my appli...
RoyX by Associate
  • 992 Views
  • 1 replies
OTA update with stm32web bluetooth app
I am trying to update my stm32wba55 firmware using stm32wba web Bluetooth app but every time its getting stuck at uploading please wait. I have successfully updated the firmware using web Bluetooth once and after that every time I am trying its showi...
Bare metal SPI implementation problem
Hi, I'm trying to get a bare metal implementation of SPI working on a STM32WB55 Nucleo board.The transmit appears to work but I cant get the receive function to work. I'm using a loop back by connecting MOSI & MISO with a jumper.When in debug I can s...
Resolved! How to set in CubeMX to use BLE extended advertising?
I am controlling BLE server using stm32wba54cgu6 chip and CubeIDE 1.18.0.1. In order to use extended advertising function, what part should I set in CubeMx?2. I think that adv_ext_app.c / adv_ext_app.h file should be created to use extended advertisi...
Will912 by Associate
  • 985 Views
  • 1 replies
Resolved! lrwan 2 gateway firmware
Hi,I’m currently working with the NUCLEO-F746ZG board. Could someone please guide me on where to find the corresponding gateway firmware binary (e.g., st-nucleo-lora-gw-at-fw-v2.0.2.bin) and the setup procedure for getting the gateway up and running?...
NITH by Associate
  • 1178 Views
