STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
Display Riverdi RVT50HQSNWC01-B
Good morning,we are working on a project using a 5 inch display (RVT50HQSNWC01-B) in the TouchGFX Designer environment. Simulation, code generation and code download to the MCU works.Problems arise when moving to STM32CubeIDE. In this environment, ca...
1bit mode white color bug
Hi, i discovered wierd behavior for touchgfx when using 1bit mode (BW or BW_RLE). Issue happens when you place black color on white one, then in editor everything looks normal but in simulator and on the board the white color overlays the black one. ...
Resolved! creating custom widget using code stm32 cube ide
Is it possible to create a custom widget in TouchGFX using code, specifically in STM32CubeIDE? I would like to start with a blank screen, add a custom widget, import the generated project into STM32CubeIDE, and then write code for the custom widget. ...
sai1 by Associate II
  • 3746 Views
  • 8 replies
  • 3 kudos
