STM32 MCUs Embedded software
recording audio on STM32H735 discovery kit
Hey folks,I am trying to record the audio on STM32H735 discovery kit, but the callback functions (BSP_AUDIO_IN_TransferComplete_CallBack) never been called. I also tried the BSP example for the board; however the audio recording demo is not working t...
How to ping stm32f746g board.
Hi I'm karthik ,now I'm working in stm32f746g board .I have try to ping static IP in stm32f746 board . So I can't able to Ping my IP address .then followed the bellow videohttps://www.youtube.com/watch?v=Wg3edgNUsTk&list=PLfIJKC1ud8ggZKVtytWAlOS63vif...
The USB VBUS doesn't work. It is not recognized.
I've been programming with a STM32F407G, but the USB VBUS doesn't work. It is not recognized by my computer. It connects and disconnects. I changed the micro USB cable, I updated the firmware of the board, I tried to connect the board in another comp...
MAlon.2 by Associate
  • 2449 Views
  • 3 replies
Performance of the AzureRTOS TCP sockets is mixed - I see high socket connection losses when running this TCP socket connect loop code. Do you have any suggestions to improve the socket handling of this code?
Attached is the test code for the tcp socket loop test. I have seen very high failures up to 26 failures out of 40 tcp socket create/connect attempts.
JVand.12 by Associate II
  • 1325 Views
  • 0 replies
Bad board or bad debugger?
Hi,I have a B-L475e-IOT01A1 board. I have been trying to learn FreeRTOS with this board. I am using STM32CubeIDE v1.12.1. When I simply load an application onto the board, it appears to load properly. However, when I try to run my code through th...
jmazz.1 by Associate II
  • 2782 Views
  • 6 replies
STM32G431C8T6 SPI bootloader whole-chip CRC cmd was acknowledged but address after that received neither ACK or NACK
my host interaction with STM32G431C8T6 SPI bootloader are functioning for a lot of jobs such as RW, but not for the whole-chip CRC. Here is the Logic analyzer captured data:Host=>BL, BL=>Host5A, A5A1,A55E,A5 cmd to run whole chip CRC00,A5......00,A50...
pxia.1 by Associate II
  • 992 Views
  • 0 replies
STM32U585 unexpected USB_RST
Hi,i have a STM32U585 MB1551C board running with a custom software.I have a tinyusb stack up and running. The device successfully appears as a vcom port on a windows pc.But unfortunately after some time, round about 10-20sec., I get another USB_RST i...
How to apply for a USB PID
Hi.We are developing a product that will use USB on an STM controller. I found several posts stating that ST offers small companies to get a PID under the ST USB Vendor ID.Is this possible - how do we apply and what does it cost?We would like not to ...
EAlbr.1 by Associate
  • 5165 Views
  • 1 replies
