STM32 MCUs Embedded software
Resolved! STM32H573I-DK Azure IoT example locks up
I have a STM32H573I-DK discovery board, purchased for the purpose of getting to grips with Azure IoT.It appears however that the example does not run properly.Compiles and links OK, and I am using the Wireless plug in board as supplied, but it gets s...
Stm32H7 PTP timestamp retrieval issue in HAL
Hi, I started a github issue for this problem: https://github.com/STMicroelectronics/stm32h7xx_hal_driver/issues/63 Realistically, the entire HAL_ETH_ReadData() function just needs to be rewritten. There are multiple flaws in it: Take for example her...
Resolved! X-CUBE-CRYPTOLIB computed SHA256 hash wrong
Hello,I would like to use the X-CUBE-CRYPTOLIB to calculate a SHA256 with a key. My implementation or the example HMAC_SHA2_AuthenticateVerify works in STM32CubeIDE 1.13.1 for an STM32L432KCU microcontroller.Source: https://www.st.com/en/embedded-sof...
Martin42 by Associate III
  • 7533 Views
  • 10 replies
  • 2 kudos
Resolved! STM32U5A5: DMA to SAI2 does not work - why?
I want to send audio samples (received via SAI1 from PDM MIC) to SAI2_SD_B as SPDIF out. It does not work, because: the DMA does not seem to write the DR in SAI2: the memory is filled with audio samplesthe DMA seems to run (I get the HAL_SAI_TxCpltCa...
tjaekel by Lead
  • 1566 Views
  • 1 replies
