STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1431 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 560 Views
  • 0 replies
Put 'mx.scratch' under source control?
After generating code for a migrated project (from TrueStudio & CubeMX), I noticed a new file 'mx.scratch' in the project's root.Is this a temp file that gets generated from other files or shall I take it under source control?
Hello, I'm usin STM32F042 nucleo-32 board, with STM32CubeIDE. I would like to test it with green led LD3 blinking. I've created a STM32F042 project, but in .ioc I can't set any pin to LED 3 (not listed).
And if I try to add "LED3_GPIO_CLK_ENABLE();" in main.c as it's done in "TM32Cube\Repository\STM32Cube_FW_F0_V1.11.0\Projects\STM32F042K6-Nucleo\Examples\GPIO\GPIO_IOToggle", I'm getting an error "undefined reference to `LED3_GPIO_CLK_ENABLE'". I hav...
undefined reference to `HAL_UART_Init'
I am trying to get UART working on a project for debugging purposes but I can't get my project to compile correctly. I have uncommented "HAL_UART_MODULE_ENABLED" in stm32f4xx_hal_conf.h but it seems to have no affect on my build at all. My Paths and ...
IDE generates bad USB code
Has anyone had success generating working USB middleware in STMCube32IDE? To date, I've tried generating a VCP or an Audio Class device for the STM32H747-DISCO, Nucleo L452RE-P and Nucleo-L4R5ZI-P. Consistently, all fail after about 30 seconds, with ...
x-cube expansions to STM32CubeIDE
Hello,How can I add x-cube...zip expansions to STM32CubeIDE?Specifically I need this one: https://my.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-audio.li...
