STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 221 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4067 Views
  • 0 replies
  • 3 kudos
Resolved! Minimum hardware configuration for a simple Lora transmision.
Hi! I'm working with the LORA E5 trying to make a small librarie to easily send/receive data through LORA protocol (Not lorawan). The given examples (Ping-Pong) use the task scheduler and the Subghy app, wich im not planning on using. My question is:...
JPrad.1 by Associate II
  • 1535 Views
How to use BLE on STM32WB5MMG with CubeMX
Hi community,I designed my own PCB and implemented the STM32WB5MMG.The device is a rather simple "Smart Home Outlet" that you can turn on/off with a Smartphone via BLE (it is just a fun project to learn some BLE).I verified that everything is working...
CKnez.1 by Associate II
  • 803 Views
  • 0 replies
  • 1 kudos
I can't manage to configure BLE on a STM32wb55cc in order for it to be connected with an application developped on app inventor
HiMe and my team designed a custom PCB containing a STM32wb55cc and needed it to be connected with BLE with an application made by ourself. Unfortunately, even if ou board is functionning pretty well with STM apps like with STM32 BLE toolbox for Andr...
How to use FreeRTOS and STM_WPAN on STM32WB5
Hi,I am using a STM32WB5MMG module and want to use FreeRTOS in combination with BLE.For ease of programming I am using CubeMX to set everything up. My goal is to have BLE up and running to be able to connect it to a Client. FreeRTOS is being used to ...
  • 1375 Views
  • 0 replies
  • 1 kudos
Resolved! Can't flash my board after following "STM32WB Getting Started Series: Part 5, CubeWB Heart Rate Monitor". What can I do to solve it ?
I followed the series of video "STM32WB Getting Started" with my P-Nucleo-WB55 board. During the 5th video "Heart Rate Monitor", I flashed the BLE_HeartRate project into my board and since this I have this message :"Target no device foundError in ini...
BTail.2 by Associate
  • 1403 Views
  • 3 replies
