STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
STM32WL LoRa Code
Hi, I am new to STM32.I am trying to implement LoRa Receiver and Transmitter code in STM32WL. I have tried to modify the Rx and Tx code using the Ping-Pong application code (subghz_phy_app.c) . I have added my Transmitter code below, can you please r...
FBrin.1 by Associate III
  • 2443 Views
STM32WB55 and read ADC from 4 channel using LL library
Hi everyone, I am trying to read ADC values from 4 different channels  PC0  ------> ADC1_IN1 PC1  ------> ADC1_IN2 PC2  ------> ADC1_IN3 PC3  ------> ADC1_IN4I am able to get different values from different channel for the 1st iteration. but from th...
mPona by Associate II
  • 1626 Views
  • 1 replies
  • 1 kudos
Resolved! How to enter stop2 mode in stm32wb, when the Ble stack opened?
According to the subject, I found I can't enter to the stop2 mode ,when i run the ble stack (APPE_Init() ) in p2p_server. I tried to use HAL_PWREx_EnterSTOP2Mode(PWR_STOPENTRY_WFI); behind the aci_gap_set_non_discoverable(); but it wasn't wor...
Htzuh by Associate II
  • 7042 Views
  • 11 replies
Resolved! Why does power management corrupt SPI registers on STM32WLE5?
When attempting to add an accelerometer to the LoRaWAN_End_Node program, on the SPI1 interface, I find that it works (in polled mode) until the board sleeps and is woken with an interrupt. Then the SPI1 Control Register 1 and Control Register 2 are c...
charles23 by Associate III
  • 4362 Views
  • 8 replies
  • 2 kudos
Is it possible to have an ADC conversion rate >= one million samples per second while having the system clock low enough to put the system into low power sleep mode (<2Mhz)?
Hello,I have an inquiry about the capabilities of my STM32WB55CE microcontroller. Is it possible to have an ADC conversion rate >= one million samples per second while having the system clock low enough to put the system into low power sleep mode (<2...
JTrie.2 by Associate
  • 1475 Views
  • 3 replies
I am not able to add opus firmware to my nucleo project.
I am not able to add opus firmware to my nucleo project. I am using Nucleo-WB55RG board and I am unable to configure the opus to my nucleo board, I am taking reference of Demo code available on website, the demo code is working the same opus I am un...
NY L.1 by Associate II
  • 861 Views
  • 0 replies
How to on STM32Cube_FW_WL_V1.1.0
Hello, I’m working with NUCLEO-WL55JC1. I’ve done some tests with STM32CubeIDE ver 1.6.1 firmware 1.0.0 (STM32Cube_FW_WL_V1.0.0) and, after some difficulty, it’s working as aspected. To fix ideas on the job done, I’ve made a Youtube video (https://yo...
FRest.1 by Associate III
  • 5224 Views
  • 10 replies
