STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
TouchGFX Low power consumption
Hello,I am making an application using Stm32f429 disco board and my question is:Do you have any solutions for low power consumption,for example, could I change brightness or turn off backlight in the running application?Thank you,Anton
qqAnton by Senior
  • 973 Views
STM32F4 DCMI with SDIO
I am attempting to implement a system which uses a 5MP camera to take photos using DCMI and save them to an SD card via SDIO. When reading through the documentation there where a few things I was unclear of. I know between the SDIO interface and the ...
ACram by Associate
  • 1086 Views
  • 1 replies
STM32F769I ,Conversion from BMP to JPEG
We are using STM32F769I eval board for storing the image to USB using the example "Camera_To_USBDisk" , when we are trying to convert the image format from BMP to JPEG . The image does not open . We are following the JPEG frame format for conversion...
SNNV by Associate II
  • 794 Views
  • 0 replies
Where to implement general behavior
Hi there,I understand the MVP architecture and I like it. However I'm not sure where to implement event handling that shall be always active. E.g. an alarm event occurs and regardless the current screen, the application shall switch to a specific ala...
mattstein by Associate II
  • 1308 Views
