STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
change the screen in TouchGFX
I m stunding TouchGFX with X-Nucleo-GFX01M1 with an example provided by STm.In a ScreenView.cpp I can see the following code (Im will copy only one part).void Screen1View::handleKeyEvent(uint8_t key) { if (animationState != ANIMATION_READY || ...
FTrom by Associate II
  • 988 Views
  • 1 replies
Resolved! Korean output not working using Unicode::snprintf()
Hello,I want to print Korean in <value> of wild cardThe encoding used in CubeIDE is attached as a picture file.The touchGFX version we use is 4.16​.​The initial value entered in wildcard is normally output as "정지".​(textArea and Typographies images a...
Hwoo- by Associate II
  • 3406 Views
Box with alpha does not work anymore
Hi!Since upgrading to TouchGFX 4.17, a box with an Alpha value does not work anymore. It just paints like as an opaque box, but not like a (semi-)transparent box.Thus I tried to create my own widget that draws a rectangle with the following code:HAL:...
STM32H747_DISCO design display issue
Had to redesign my STM32F769 design take the STM32H747 (silicon supply issues). So I cloned the H747_DISCO pin for pin with the exception that I've no external Flash. I then built a TouchGFX test app based on the H747_DISCO, removed the QSPI need in ...
Bruce1 by Associate
  • 710 Views
  • 0 replies
