STM32 MCUs Embedded software
SSL/TLS Handshake failed - Unrecognized Name.
Hi,I was trying for create a simple ssl server/client communication. I am running client now and monitor the Wireshark log. I am able to see the Client Hello message also verified the packet format ciphers and another parameters are correct in client...
AFaya.1 by Associate III
  • 1259 Views
  • 0 replies
Seeing an issue with USB interrupts on STM32H742 only on Endpoint 1 USB Enumeration works fine. I am seeing HAL_PCD_DataOutStageCallback for endpoint 0 but not HAL_PCD_DataOutStageCallback for endpoint 1. Any ideas what I might be missing?
Initialization sequence:hpcd_USB_OTG_FS.Instance = USB_OTG_FS; hpcd_USB_OTG_FS.Init.dev_endpoints = 9; hpcd_USB_OTG_FS.Init.speed = PCD_SPEED_FULL; hpcd_USB_OTG_FS.Init.dma_enable = DISABLE; hpcd_USB_OTG_FS.Init.phy_itface = PCD_PHY_EMBEDDED;...
SMura.4 by Associate
  • 937 Views
  • 0 replies
NUCLEO-STM32F767ZI and STM32 CUBE IDE
Good day,I have a NUCLEO-STM32F767ZI and a problem with the STM32 CUBE IDE. When I create a project in version 1.5.1 with ETH, FreeRTOS and LWIP everything works fine. When I create the same thing in the latest version, the generated code falls into ...
DJeze.1 by Associate II
  • 2994 Views
  • 4 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
