STM32 MCUs Embedded software
VTaskDelay does not wait what I espect
Hello,STM32L476.FreeRTOS 10.3This call:while(1){ vTaskDelay(pdMS_TO_TICKS(1000)); HAL_GPIO_Toggle...... }should wait 1 second, toggle a pin again and again. With a single task, it looks ok:On this graph the bottom pin toggles every secon...
JulienD by Senior
  • 4381 Views
  • 3 replies
Is NVIC_PRIORITYGROUP_4 (3) same in effect as 0 ? (32F417)
Cube MX generates a call with a value of NVIC_PRIORITYGROUP_4 which is defined as#define NVIC_PRIORITYGROUP_4     0x00000003U /*!< 4 bits for pre-emption priority                           0 bits for subpriority */but if you follow the function NVIC_...
PHolt.1 by Senior III
  • 5282 Views
  • 4 replies
Regarding Webserver Application
Greetings !I am using STM32F743 Evaluation Board for my Project . I am currently working on Firmware Upgrade over the Ethernet . Can you kindly provide any sample application / procedure for the same .Thanks in Advance
PG.9 by Associate III
  • 1370 Views
