STM32 MCUs Embedded software
Resolved! How to modify boot configuration bits STM32G030?
Hello everybody:I’m facing the following problem. To boot the microcontroller right know I have pin PA14 – BOOT0 to GND through a 10K pull down resistor (This pin is also shared with SYS_SWCLK) and BOOT0, nBOOT_SEL bit to 0 -> Boot area main Flash me...
JSope.1 by Associate II
  • 6523 Views
  • 4 replies
Resolved! STM32F1 - no HAL error, no SPI signal
Hello!I'm trying to run SPI in Transmit Only Master mode.It's strange - result of HAL_SPI_Transmit is HAL_OK but I can't see any signals on SCK and MOSI pins.main.cint main(void) { /* USER CODE BEGIN 1 */   /* USER CODE END 1 */   /* MCU Config...
MLemb.2 by Associate II
  • 3582 Views
  • 6 replies
Timer and uart does not work at the same stime
Hello,In my code there are custom bootloader part and user application part. I init watchdog timer and refresh watchdog timer in the bootloader part and user app part. The code goes to user app from bootloader by jumping address. Likewise, The code g...
MTapu.1 by Associate II
  • 2850 Views
  • 5 replies
