STM32 MCUs Embedded software
Resolved! DMA/STM32F103: memory to USART2 TX.
Hi all, I am successfully transferring from a memory location to the data register of USART2 Tx using DMA operation. And the USART2 has been used by the  printf()  to output to the PC. What I don't understand is, what moderates the rate at which DMA ...
LarryC by Associate
  • 2255 Views
  • 3 replies
  • 1 kudos
Resolved! STM32H573i-DK: Poor TCP TX Performance, iperf
Hey, i have ported the iperf2 example(https://github.com/STMicroelectronics/STM32CubeH5/tree/main/Projects/NUCLEO-H563ZI/Applications/NetXDuo/Nx_Iperf) of the H563 board to the H573i-DK Board.It pretty much works as expected now, but the TX performan...
funkii by Associate III
  • 4702 Views
  • 5 replies
  • 4 kudos
ThreadX tickless mode, can't get into Sleep mode
I have problems in getting this working. I moved from FreeRTOS to Azure RTOS, and I found out that in general there's lot less information on this RTOS. So I've been looking into the few resources, but I'm afraid I'm missing some important points. Ar...
paolog by Senior
  • 5383 Views
  • 5 replies
  • 5 kudos
Timer PWM DMA Pulse generation STM32F303
Hi, My aim is to generate a pulse sequence using the PWM timer and DMA analogue to Stm32 custom signal generation using pwm and dma with a STM32F303 on RTX5 RTOS. I need Pulsefrequency with max. 500khz, i use the STM32F303RCTx with PA2 as output Here...
pedahl by Associate II
  • 2917 Views
  • 4 replies
How to port X-CUBE-TCPP to STM32G0B1RE
Hello Everybody,I sucessfully included the X-CUBE-TCPP software expanison onta a NUCLEO-G071RB Board.After some inital tests we decided to switch to the NUCLEO-G0B1RE Board for more flash as the Getting Started PDF (https://www.st.com/resource/en/use...
VH by Associate
  • 2383 Views
  • 1 kudos
Resolved! STM32F407 LWIP returning data to client
I previously posted here when I was having issues with my STM32F407 board that I have configured as a HTTP server.https://community.st.com/t5/stm32-mcus-products/where-to-find-lwip-incoming-payload-data-for-webserver/m-p/640137This is a follow-up pos...
