STM32 MCUs Embedded software
stm32f401ccu6 disconect while programming (NOOB HERE)
Hello guys Im new here, sorry if I posted to wrong post.Im trying to program stm32f401ccu6 with existing .bin file. I tried via ST-LINK V2 (clone) and Im getting ''('' where serial numbers should be. When connected via USB C the board get connect to ...
ak1ca by Associate
  • 1005 Views
  • 1 replies
fast data transmission from MCU to PC
 What is the fastest way to transfer data from an MCU to a PC?I have an stm32h723zg that I want to use to transfer 40Mbits/sec data to a PC, but I am not sure what is the way to achieve this I tried USB CDC but got only 0.5Mbits/sec due to the limita...
DEska.1 by Associate II
  • 3332 Views
  • 3 replies
  • 1 kudos
STM32 Nucleo 767ZI FreeRTOS benchmark
Im currently porting a CPU performance benchmark from ESP32 to STM32 that uses FreeRTOS. Im unable to make it work due to some errors that continue appearing that might suggest there is a stack overflow, but increasing the stack size doesn´t help.Deb...
Alex2968 by Associate II
  • 2918 Views
  • 7 replies
  • 1 kudos
STM32L152RET6 - BOR Setup failed
Hi folks, this is my first post here on this forum and I expect to find an answer to this issue I currently have.Just so you know, my current hardware setup involves an STM32L152RET6  MCU on our custom board which we have been able program using a Nu...
Resolved! LAN8742A no clock output
HiI am using STM32H753VIT6 together with LAN8742A.I have some questions regarding the setup.1. My schematic for the LAN8742A is shown in the picture below. I plan to use the PHY to generate the clock. To my knowledge this requires a pulldown resistor...
tyassin by Associate III
  • 3401 Views
  • 1 kudos
