STM32 MCUs Embedded software
Resolved! Nucleo STM32G431KB I2S
HelloI tried to implement I2S on the chip in question to send the data acquired by the on-board ADC (I tried both 8-bit and 12-bit) with DMA active on a curved buffer and half-word data size. The data should be read by an ESP32, connected to it on th...
AntoR by Associate III
  • 3035 Views
  • 4 replies
  • 2 kudos
Resolved! STM32U545REI6Q Bootloader GPIO config
AN2606 does a very good job of describing communication peripheral usage by the bootloader, but not so much GPIO pins.Can I get a description of how each of the GPIO pins on the ST32U545REI6Q is configured by the bootloader? This could be important i...
CSmit.4 by Associate II
  • 1508 Views
  • 1 kudos
Trying to programmatically get timer details
I use CubeMX to generate the set up code for clocks and peripherals in the STM32H7A3 I'm currently using for my current work.  I'd like to calculate the timer and low-power timer call back periods programmatically without having to type in magic numb...
magene by Senior II
  • 3401 Views
  • 3 replies
