STM32 MCUs Embedded software
Resolved! STM32H723ZG - no target detected
Hello everyone, I've designed a custom board with STM32H723ZG, previously based on STM32F767ZG. When I connect board with ST Link V2 prog through SWDIO, SWDCLK and GND, I get response that no target has been detected. I'm currently using ST-Link Util...
Mylossh by Associate
  • 3935 Views
  • 5 replies
  • 8 kudos
STM32H503 TIM3 global interrupt
 I'm programming a STM32H503CBUx Timer3. NVIC settings are such that the count down event is trapped in void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef* htim)This is a global interrupt routine that takes care for other timer interrupts as well a...
Resolved! STM32L4: Does the USB device even use the heap?
I am using the USB CDC driver code provided by ST in stm32cubeide, and am trying to figure out a proper minimum heap size. I have found various slightly conflicting answers, but the consensus seems to be that 512 bytes is not enough.In the same appli...
EThom.3 by Senior III
  • 610 Views
  • 2 kudos
CCID USBD transfer block (splitting)
Hello,I'm currently preparing the firmware for a USB NFC reader (CCID). I'm working with the STM32F103 MCU and the ST25R3916 NFC reader.The STM32F103 MCU is programmed on a CCID USB device using the CCID USBD driver provided by STM32. The MCU acts as...
