STM32 MCUs Embedded software
Pin initialization defect on Nucleo F767ZI
In LwIP HTTP server demo, ethernetif.c, HAL_ETH_MspInit():...  /* Output HSE clock (25MHz) on MCO pin (PA8) to clock the PHY */  HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_PLLCLK, RCC_MCODIV_4);...According to the schematic, this pin is the USB SOF i...
Sean1 by Associate II
  • 641 Views
  • 0 replies
PLL initialization defect on Nucleo F767ZI
In main.c, SystemClock_Config(), the PLL is set up as follows:... RCC_OscInitStruct.PLL.PLLM = 25; RCC_OscInitStruct.PLL.PLLN = 400;  ... RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;...The implication is that the clock is 25MHz, and being divided down...
  • 814 Views
  • 0 replies
STM32F105 USB Device not detected on PC
I have generated USB CDC code using STM32CubeMX with firmware 1.7.0. When I run the code, nothing is detected on the PC. I have disabled VBUS sensing and made sure USB peripheral Clock is enabled. I am using external 25MHz crystal and verified by PL...
fm by Associate II
  • 722 Views
  • 0 replies
