Entry to Stop mode, and exit from Stop mode.
mateuszdabek
Posted on October 28, 2016 at 12:09
Someone does know STM32 L series ? I would like to know something about Low power mode. In my project I use battery. I would like to extend work time on battery. I don't know which low power mode I should  choose?
Features:
As low power consumption as posiible,
In low power mode must work timer,(possibility wake up mcu every fixed time(1s) )
Ability  Wake up by external interrupt.
In my opinion I should use Stop mode. I am beginner in programming STM32.
I use HAL library, but I can  write some code without any library.
When I use this below function:
HAL_PWR_EnterSTOPMode(PWR_MAINREGULATOR_ON, PWR_STOPENTRY_WFI); MCU go to stop mode. How I can wake up MCU from stop mode. If someone have example code, please share here.
Thank you in advance for help me.
#stm32 #hal #stop-mode #lowpower
Nesrine M_O
Lead II
Posted on October 28, 2016 at 13:22
Hi d_bek.mateusz,
 Welcome to STM32 community.
Someone does know STM32 L series? I would like to know something about Low power mode.
1/ could you please precise which STM32L series you expect to use?
http://www.st.com/content/st_com/en/products/microcontrollers/stm32-32-bit-arm-cortex-mcus/stm32l4-series.html?querycriteria=productId=SS1580
http://www.st.com/content/st_com/en/products/microcontrollers/stm32-32-bit-arm-cortex-mcus/stm32l1-series.html?querycriteria=productId=SS1295
http://www.st.com/content/st_com/en/products/microcontrollers/stm32-32-bit-arm-cortex-mcus/stm32l0-series.html?querycriteria=productId=SS1817
2/To have idea about low power modes you  have first to read carefully the Power control (PWR) chapter in your related reference manual, then a set of application notes are provided to help you to start with  STM32 power features also I recommend you to get trained watching the
http://www.st.com/content/st_com/en/support/learning/stm32l4-online-training.html
3/If I suppose that you use STM32L4 series:
•You find a set of examples for low power modes under this path: STM32Cube_FW_L4_V1.5.0\Projects\STM32L476RG-Nucleo\Examples\PWR
•Also you can have a look to these application note witch help you to start :
http://www.st.com/content/ccc/resource/technical/document/application_note/9e/9b/ca/a3/92/5d/44/ff/DM00148033.pdf/files/DM00148033.pdf/jcr:content/translations/en.DM00148033.pdf
http://www.st.com/content/ccc/resource/technical/document/application_note/5c/cb/90/97/4b/84/4e/81/DM00216518.pdf/files/DM00216518.pdf/jcr:content/translations/en.DM00216518.pdf
-Syrine-
