Other tools (MCUs)
New STM32 VSCode extension V2.0.0 released
Changelog Version 2.0.0 V2.0.0 implies a breaking change: CMake project generation has been moved from VS Code to STM32CubeMX v6.11.0 (and later). VS Code solution no longer has dependency on STM32CubeIDE (.cproject-files)VS Code solution no longer r...
VSCode How to install VCPKG on VSCode with Zscaler/Proxy
Issue:  The VSCode don't have the ability to route the extension network requests to the proxy (only VSCode application network is routed to the proxy) I -  the clean way (applies to network with Zscaler installed) ask for a Zscaler power user profil...
NawresGHARBI_1-1704443433898.png NawresGHARBI_2-1704443503313.png NawresGHARBI_3-1704443553581.png NawresGHARBI_4-1704443616206.png
STM32F3Discovery : Unknown target connected / Keil
Posted on December 11, 2012 at 20:56I just got a new STM32F3Discovery board and when I am trying to start a debug session using Keil, it is giving me an error saying ''unknown target connected'' and it fails to download code into the flash. Has anyo...
PWM input from Simulink-> PWM output TIM1
Posted on February 05, 2018 at 22:08Hi, after some problems with the interface between Simulink and CubeMX, I've managed to get the TIM1 of the STM32F767ZIT working at a desired frequency and duty cycle using the next blocks:My question is, is there...
Porting code from IAR to TrueStudio
Posted on January 28, 2018 at 18:57Hi,I had been using IAR Embedded Workbench for programming and burning codes on STM32F7. Since the release of TrueStudio 9, I thought it would be wise to switch to a free version ahich has no code size limitations....
How to printf in Keil ( Nucleo L073RZ)
Posted on May 26, 2016 at 18:16Hi,Currently I am using ST nucleo L073RZ with Keil testing with stm32cubeL0 example code. Is there any way to do a printf in Keil say print out the value in the debug printf window. #printf #keil #nucleo #stm32l0
STM32L452RE Nucleo64 & Mbed
Posted on September 24, 2017 at 03:34When will the STM32L452RE Nucleo64 board be supported on mbed?This was asked on the Mbed site over two months ago with no response there.https://os.mbed.com/questions/78534/STM32L452RE-compatibility/ #nucleo #mbe...
Truestudio + J-Link = endless pain
Posted on January 23, 2018 at 15:54Hello there,Recently I decided to make a swap from Eclipse + OpenSTM32 + ARM Gnu eclipse plugin. This setup was working quite flawlessly, but since a dedicated solution is available now why not try it.I was surpris...
