STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 221 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4066 Views
  • 0 replies
  • 3 kudos
Resolved! STM32WL store NVM context Lorawan
Hi, I need some help trying to undestand this operation in Lorawan_end_node example projectnvm_size = ( ( sizeof( LoRaMacNvmData_t ) + 7 ) & ~0x07 ); in the code below:Maybe it is so simple, but i thought that it would be something like that nvm_siz...
RPaja.1 by Associate II
  • 3091 Views
  • 3 replies
[Nucleo -STM32WB55 ] How to enter the low power mode and wake up the device through the wake-up pin when the thread function is turned on ?
Hello everyone:​I created a thread udp project through the official Max 6.7 version of the IDE and applied it to two Nucleo -STM32WB55 development boards for thread data transmission.(One as FTD equipment, one as MTD equipment)​​I want to let the MTD...
_legacyfs_online_stmicro_images_0693W00000bjRunQAE.png _legacyfs_online_stmicro_images_0693W00000bjRrQQAU.png _legacyfs_online_stmicro_images_0693W00000bjRvWQAU.png _legacyfs_online_stmicro_images_0693W00000bjRw0QAE.png
STM32WB USB VCP Driver not working?
Hello ST,I am using STM32WB Necleo Board to test USB as VCP. my reference project is BLE_MeshLightingLPN (USB Dongle) project and same way i am implementing all libraries and modification in BLE_MeshProvsion... CFG_USB_INTERFACE_ENABLE 1A new VCP por...
_legacyfs_online_stmicro_images_0693W00000bjCSjQAM.png _legacyfs_online_stmicro_images_0693W00000bjCStQAM.png _legacyfs_online_stmicro_images_0693W00000bjCTXQA2.png
Resolved! STM32WB55 User Manual RCC register is missing bit 18????
I am trying to incorporate the X-Cube-EEPROM package into an existing STM32WB55 Nucleo design that I have. In the process one of the compile errors refers to an RCC bit:​'RCC_CR_HSEBYP' undeclared (first use in this function); did you mean 'RCC_BDCR...
SWenn.1 by Senior III
  • 1216 Views
