STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
How do I stop a forEachChild callback chain?
When I want to execute a certain callback after a certain widget has been pressed, I use the function forEachChild to reach the wanted callback. But during the execution of this callback, I remove the container from the screen to change the visual en...
MrJob by Associate II
  • 673 Views
  • 0 replies
STM32L4R9 Discovery kit hanging
HiI am using STM32L4R9 Discovery Kit. Here I am using the template code for text display , the controller was hanging , while I am call the lcd refresh function.
RKasi by Associate
  • 910 Views
  • 1 replies
Small example to use touch gestures.
Hello,I would really appreciate if you could provide a small example demonstrating how one can use touch gestures with TouchGFX. For instance, something showing how to display a rectangle upon doing a slide motion of a finger to the left and hiding i...
GMeur by Senior II
  • 626 Views
  • 0 replies
Compiling for STM32F769I Discovery
Hi. Following this document:https://touchgfx.zendesk.com/hc/en-us/articles/360020208091-Configuring-STM32F769I-DISCOand believe all the required changes have been made including applying comments to exclude the STM32 fonts as per this article. Howeve...
Mon2 by Senior III
  • 4005 Views
  • 16 replies
Question about STM32 TFT LCD Multi Layer
stm32f429i discovery board is undergoing various tests.There are many Layer-related functions in the BSP functionWhat is the difference between using 1 Layer and using Multi Layer when using LCD?Let me know if you have related videos or links.
DSEO by Associate II
  • 668 Views
  • 0 replies
Blank Screen when STEMWIN code generated from CubeMx
Hi,I am having this issue with STM32F469 and 769 Discovery boards. I am trying to create a project in CubeMx with ADC enabled and a STEMWIN Window created using GUIBuilder. When I try to generate this code and run it in SW4STM32, the Discover screen ...
AMoha.81 by Associate II
  • 2383 Views
  • 6 replies
