STM32 MCUs Embedded software
malloc() causes hard fault with newlib-nano
If I understand malloc() correctly, then it should either return NULL (if out of memory) or a valid pointer.However, certain sequences of calls to malloc() cause a hard fault instead. Here is a minimalistic sample project for an STM32L431 with 64kB R...
GMock.1 by Associate II
  • 2597 Views
  • 1 replies
  • 1 kudos
Can Netx duo work with freertos
Hello, I would like to know if netx duo is able to work based on freertos and if there is already an implementation for it, since our work was based on freertos implementation. Or if there is an oslayer for netx duo for freertos.
PeterMu by Associate II
  • 2597 Views
  • 4 replies
  • 3 kudos
RTOS ThreadX support in STM32G0xxx mcu platform
Hi Team I am using stm32g0x mcu platform. Till now I am writing normal code without using rtos. Does this mcu support RTOS ThreadX support in STM32G0xxx mcu platform. Please share the process to enable using Stm32 cubeide tool.Thanks, Kumar
Akuma.6 by Associate III
  • 2903 Views
  • 4 replies
  • 1 kudos
stm32f411 use mutliple adc
Hello everyone, I want to use 4 sensors with 4 channels in a single ADC on the stm32f411ceu6. There was no adc prescalar in clock config. Actually, I used 2 sensors using 2 channels. With the same logic, when I try to use all 4 of them, it measures i...
atprk by Associate
  • 2032 Views
  • 1 replies
  • 1 kudos
Resolved! NUCLEO-H723ZG Issue with ETH and ping
Hello,Sorry if i'm asking a dumb question or if someone already ask it, but I have some problem pinging my NUCLEO-H723ZG using Ethernet and lwIP without FreeRTOS.I already tried the tutorial to create a project with Ethernet and lwIP step by step , i...
SDeha.2 by Associate II
  • 2430 Views
  • 3 replies
  • 1 kudos
