How to use CMSIS to set a bit or register
LMorr.3
Senior II
Each time I call SET_BIT to set a bit the register value remains at 0. All registers are 0 even after writing, as though they are read-only. For example, the following does not set the bit:
DMA2_Stream0->CR |= ((uint32_t)1);
What am I missing?
Thank you!
>>What am I missing?
Probably a clock
>>What am I missing?
Probably a clock
Yep, that was it, thank you!
