STM32 MCUs Embedded software
RTC loses one second after every reset
using stm32h753bitx controller and their latest HAL drivers. On the every reset RTC loses one second. It also loses time while the device in idle condition.My devices uses main battery power and coin cell battery for backup.Here's my RTC initializati...
Sanjay by Associate II
  • 2268 Views
  • 4 replies
STM32H7 PCM1808 endianness
I am trying to get the PCM1808 ADC working on my STM32H7 using Cube IDE, but get stuck regarding endianness.I understood STM32 is little endian and i2s is big endian. I am trying to receive 24 bit data via DMA but when reading my DMA buffer I am not ...
TMich.1 by Associate III
  • 2444 Views
  • 1 replies
FileX NAND Flash performance problem
I using the stm32L4+MT29F2G01 and the latest Filex library from ST 2.0.0 (6.2.0 AzureRTOS). After the format, the performance is satisfactory for me (250ms write 2048B), but after saving a few files of about 1MB each, the efficiency drops sharply, th...
Pawol by Associate
  • 4406 Views
  • 4 replies
Failed to receive file via tftp
I am working on a tftp client program that receives a file from a tftp server. I found the tftp client library below and ported it. https://github.com/particle-iot/lwip/blob/master/contrib/examples/tftp/tftp_example.c   The file is received in debugg...
jmyoo by Associate II
  • 3776 Views
  • 8 replies
Resolved! X-CUBE-STL Integration with RTOS
Hi ST Team,I am planning to use the X-CUBE-STL library with the STM32H7 dual-core microcontroller and RTOS (ChibiOS, FreeRTOS). Could you please guide me on how to integrate X-CUBE-STL with RTOS like ChibiOS, FreeRTOS, SafeRTOS, etc.? Additionally, a...
STM32 OpenBooLoader communication problem
Hello to the whole communityDuring a recent project where we use the STM32G491VETx version as a microcontroller, I inserted as bootloader "STM32 OpenBootLoader V3.0.1" extracted from the package"STM32Cube_FW_G4_V1.5.0" downloaded from the ST website....
RS62 by Associate
  • 966 Views
  • 1 replies
