STM32 MCUs Embedded software
Calculating Flash data CRC using DMA
I am currently working on calculating the FLASH CRC through DMA on the NUCLEO-H755ZI-Q development board. I've successfully read from flash and calculated the CRC using DMA in memory-to-memory.Now, I'm facing challenges while configuring DMA for DMA_...
IAP vs Bootloader for STM32U5 for OTA FW upgrade
Hi,I'm studying a way to do OTA FW upgrade for a STM32U5A5 MCU using a LTE modem and SPI Flash external memory. My environment is: STM32CubeIDE v1.16.1 with STM32CubeMX v6.12 and FW_U5 v1.6.0. I'm also using  FreeRTOS.I was checking the native Booloa...
kalak by Associate II
  • 3065 Views
  • 4 replies
  • 2 kudos
Mutliple TCP clients on STM32H563 with NetXDuo
I have a question regarding the tutorial "Handling multiple TCP clients on STM32H563 with NetX Duo" written by @STea .See https://community.st.com/t5/stm32-mcus/handling-multiple-tcp-clients-on-stm32h563-with-netx-duo/ta-p/695030 In the first section...
SiSte by Associate II
  • 3004 Views
Resolved! X-CUBE-EEPROM 7.0.0 bug
While implementing EEPROM emulation on an STM32G0 (although I believe this would apply to all supported families) I have discovered what I believe to be a bug in eeprom_emul.c:Although ConfigureCrc() is called at the beginning of EE_Init to turn on t...
Enabling HTTPd breaks the whole project
Hi, I'm playing around with lwIP on my Nucleo-H743ZI and I was able to make ping work, udp/tcp echo and snmp too. But when I enable HTTPd the project doesn't wont do compile I just get a lot of undefined references, I tried to make a new project and ...
abeslic by Associate II
  • 14010 Views
  • 15 replies
  • 10 kudos
