STM32 MCUs Embedded software
Resolved! ADC Sampling and Display
As is well known, the ADC sampling rate is on the order of microseconds, while the display task may only refresh once every 100 milliseconds. In an RTOS, how can the display task and ADC sampling values be synchronized? With such a long display refre...
xwq370 by Associate
  • 206 Views
  • 1 kudos
Resolved! X-CUBE-GNSS1
I have a project that will be using the LIV4F chip. I downloaded and installed X-CUBE-GNSS1 but its description says it is for the LIV3F. Is it compatible with and will it function with the LIV4F chip? I will be using it on the STM32G474CEU6.Thanks!
hritter by Associate II
  • 155 Views
  • 1 replies
Resolved! STM32H533 and CubeMX generated project for CubeIDE
Hello, all my tools are updated to last ones, and software packages too. I start an empty project using X Cube FreeRtos 1.5 (just a default task). Play the soft with debug, and after a few seconds, press "Suspend" button to break the running program....
lclor by Associate III
  • 956 Views
  • 16 replies
