STM32 MCUs Embedded software
STM32H745 Pinging
Hello everyone,   I am trying to establish a connection between my STM32H745I(Discovery kit) and my computer and the jumpers are set to STLK for programming, and I also have connected the board through LAN to my computer directly. I have set my compu...
FatFS and D-Cache not working together
Issue with FatFs and D-Cache on STM32 (CubeMX Library)I'm having issues using FatFs with D-Cache enabled on an STM32. After searching, I found several posts reporting similar problems, but I haven't seen a clear solution.I’m using the FatFs library t...
How config I3C Target to send NACK
Hi, I would like to know how to disable address acknowledgment in I3C when operating as a target (with an already assigned address) to temporarily hold communication, similar to the OA1EN bit in I2C.Thanks,
RFerr.3 by Associate II
  • 3469 Views
  • 4 replies
memcpy() function not working
Hi,I'm using the STM Cube IDE version 1.15.1 along with NucleoG474RE board. My C application requires the use of memcpy(). The memcpy() function should copy the values from an unsigned char source buffer to the unsigned char destination buffer. This ...
i2c error
Dear ST I have some question about i2c read functions Currently we use zephyr os (version 3.4.0) the stm32f412RGT used as the host and the host  reads a 5-byte value from another mcu used as a slave throughi2c the following problem occurs once every ...
hongjo by Associate II
  • 2305 Views
  • 6 replies
  • 3 kudos
