STM32 MCUs Embedded software
ethernet to work on nucleo-h753
i have the nucleo-h753 evolution board , and i want to activate the ethernet port to perform udp client .i want the implementation without FREERTOS  i followed the steps described in the link below :https://community.st.com/s/article/How-to-create-pr...
abeba.1 by Associate III
  • 5527 Views
  • 5 replies
  • 1 kudos
STM32 I2C interupt not being pended
I am trying to write my own I2C driver but I have been having an issue that after sending the start condition both SCL and SDA lines go low and stay that way. After some painful debugging I realize that the I2C event interrupt handler is not being ca...
Resolved! STM32H7 SPI and DMA transfer/receive issue
I want to transfer a buffer and receive a buffer of data using a full duplex SPI port with DMA on a STM32H7S3L8H (on the NUCLEO-H7S3L8). My problem is I am not able to modify the transfer buffer and have the modified version sent. I only need to modi...
JBias by Associate III
  • 1712 Views
  • 3 replies
  • 1 kudos
Resolved! HAL UART Issues
Hi, I had to recently work on an application that makes use of the UART, and encountered some issues in the HAL (most recent version provided by CubeMX):1) Hal bug?Drivers/STM32G4xx_HAL_Driver/Src/stm32g4xx_hal_uart.c, Line 3825:3831if (!(IS_LPUART_I...
