STM32 MCUs Embedded software
Bootloader with FreeRTOS
Dear friendsI am trying to develop a bootloader with STM32F469BIT mcu. First of all, I divided the 2048K flash area allocated to me into zones according to certain sector addresses. These areas;Bootloader -> FLASH (rx) : ORIGIN = 0x8000000, LENGTH = ...
mmercan by Associate II
  • 2162 Views
  • 5 replies
STM32N6 FSBL vs Application
Hi,I'm starting to try things with the new N6 MCU serie using the NUCLEO-N657X0-Q devboard on STM32 CubeIDE 1.18.0.I'm pretty confused with the new .ioc project configuration and the possibility to configure my board on "FSBL" or "App".I generated a ...
jmF by Associate II
  • 1912 Views
  • 1 kudos
Resolved! How to use analogue pins (not ADC) to read voltage?
hi all, I am using STM32F733xx and i want to read the Vout i will be monitoring is between 1-5v, to read that i have used analogue pins PG13, PH3 ,PH2,PG14, PE2,PE3, PE6, PE4,PE5,PF1,PF0,PF2I already have the PCB so i cant change the design can anyon...
sal92 by Associate II
  • 1927 Views
  • 5 replies
  • 6 kudos
Resolved! EEPROM Emulation not working in code >64K
Split from EEPROM Emulation: meaning of the VirtAddVarTab as this is a new question.The eeprom emulation in my simple trial sofware is working fine. The code is quite small.I tried to use this software inside a more complex program, larger than 64K, ...
OldSTMan by Associate II
  • 2424 Views
  • 8 replies
  • 2 kudos
