STM32 MCUs Embedded software
Problem with FFT Functions in FreeRTOS
Posted on November 30, 2017 at 09:06Hello,I'm running freeRTOS on STM32F4. I have no problem with using cmsis-dsp functions without freeRTOS.But when I want to call a function (in which cmsis-dsp functions like arm_cfft_radix4_f3,arm_rfft_f32 ,... a...
Dual Host RTOS USBH_Init
Posted on November 23, 2017 at 17:17Hi,I�m having some issues getting a dual FS USB Host RTOS configuration running based on a STM32F746 target.Connection events and callbacks events work correctly.When I use the USBH_Init() function for initialisin...
paul2 by Senior
  • 1169 Views
  • 1 replies
stm32f373 SDADC simultaneous continuous sampling
Posted on November 27, 2017 at 14:58Hello,i'm going to read SDADC1, SDADC2, SDADC3 (stm32f373) in continuous mode with DMA,Setup: Regular conversion, multimode disable,software start for SDADC1, Synchronous trigger for SDADC2, SDADC3.Each SDADC conf...
mailbox by Associate II
  • 976 Views
  • 0 replies
Using SDMMC with STM32L476 in 1-bit mode
Posted on November 15, 2017 at 19:42Hi there,I'm trying to get the SD 1-bit  interface working on my STM32L476. I generated the code with the STM32CudeMX.So that's my problem: The init function ''MX_SDMMC1_SD_Init'' [1] stucks in a loop. So, I used ...
_legacyfs_online_stmicro_images_0690X0000060N06QAE.png _legacyfs_online_stmicro_images_0690X0000060N0BQAU.png _legacyfs_online_stmicro_images_0690X0000060MyzQAE.png _legacyfs_online_stmicro_images_0690X0000060MvMQAU.png
SVD files for the STM32L433 are missing
Posted on November 22, 2017 at 11:28Hi,When trying to download the SVD files from the STM32L433 page, the archive actually contains the wrong files. It instead has the files for the STM32L4+ series. Who can I report this to so that it can be fixed#s...
jeremyh by Associate II
  • 1601 Views
STM32F746 for dsp audio effects
Posted on November 25, 2017 at 17:09Hello everyone,a while ago I started looking into the STM32746 to test some DSP audio effects, but I don't have much experience with STM32 MCUs. I mainly had issues with sdram access (see https://community.st.com/...
ffr3akk by Associate II
  • 989 Views
  • 0 replies
