STM32 MCUs Embedded software
Resolved! How to edit low level disk i/o for FatFS+SPI?
Posted on April 08, 2018 at 20:55Dear ST community,I am currently working on being able to control a micro SD card via SPI and FatFS. Now to my initial situation. I have already generated a project via STCubeMX. The project information can be found ...
set priority between SPI and UART
Posted on April 07, 2018 at 15:03hello everyone!   I'm currently working on a project, in which I'm mainly using spi [ for MICRO SD CARD and EEPROM communication ],  uart [ GSM communication ] and timer [for certain process management]. my project i...
When will HAL be RTOS-aware?
Posted on April 07, 2018 at 18:07This has been asked many times going back some 4 years, but has never been answered with any commitment by ST.There's even this teazer in stm32f?xx_hal_def.h:&sharpif (USE_RTOS == 1U)  /* Reserved for future use */  ...
Frank CA by Associate III
  • 1670 Views
  • 0 replies
  • 1 kudos
Alternative to MSC device (MTP)
Posted on March 26, 2018 at 07:30Hello there,I was able to implement an MSC class device basing on external qspi flash memory ( https://community.st.com/message/190720-re-qspi-fatfs-usb-mass-storage?commentID=190720 ).It works, but after some resear...
Bug in HAL SD driver code
Posted on April 06, 2018 at 02:31 I spent the day chasing a bug that I had discovered a year ago, but forgot about. As detailed here: https://community.st.com/thread/39452-sdio-demo-code-doesnt-work-with-usd-ver-1 , there is a flaw in STM32...
stm32l SPI slave parcel shift problem
Posted on April 05, 2018 at 16:01Hello.I'm trying to establish SPI connection between the STM32l151 MCU and a linux-powered processor module. The MCU is located on a custom PCB and acts as a slave, the CPU is a master. Connection speed s 100 kHz. Th...
