STM32 MCUs Embedded software
IAP over UART
Hello all,I know this has been probably done to death,but Just a quick link or some pointer if possible :I am using an ESP8266 to flash code to an STM32F103 over the UART.Basically I want to do what the "Flash Loader Demo" STM utlity does, by using t...
TFern by Associate III
  • 1761 Views
STM32 MCUs IDE
Forwarded fromhttps://www.embedded-computing.com/home-page/rt-thread-iot-os-launches-rt-thread-studioRT-Thread has launched RT-Thread Studio, an integrated development environment for the open-source RT Thread IoT RTOS. A customized version of the Ec...
PPete.11 by Associate II
  • 968 Views
  • 1 replies
  • 1 kudos
DFSDM output array values are wrong
I am using STM32F413CG MCU , I'm trying to interface DFSDM to have audio samples to send it to I2SI am running DFSDM audio clock at 61.44MHZ and clock divider is 20 , FOSR = 64 , Sinc 4 Filter , right shift =0 my problem is that DFSDM output array va...
0693W000000V4ebQAC.png 0693W000000V4eRQAS.png 0693W000000V4eHQAS.png 0693W000000V4eCQAS.png
HNabi.1 by Associate II
  • 1044 Views
  • 0 replies
Doxygen bug in usb_device.c.
Getting some doxygen warnings:usb_device.c:94: warning: unbalanced grouping commandsusb_device.c:98: warning: unbalanced grouping commandsI think the file is missing a couple of @defgroup or @addtogroup./* USER CODE BEGIN Header */ /** ***********...
MSipo by Senior II
  • 775 Views
  • 0 replies
HEX to DFU without files in C#?
Hi everyone,I'm working on an app to configure an STM32 based DFU device and I don't want to deal with the file system. Everything works now except one step, going from Intel HEX to a DFU image directly so I can write it to the device. The ST DFU ima...
DVoro.1 by Associate
  • 974 Views
  • 1 replies
Bootloading Using Pattern 10
Trying to figure out how to bootload the Stm32h745 using the BOOT0 and BOOT_ADDX. AN2606 / AN4938 says to use pattern 10, yet that shows the BOOT0 pin can be low OR high with the only difference being the ADDRX. We're interested in only using th...
EZamo.1 by Associate III
  • 1997 Views
  • 3 replies
