STM32 MCUs Boards and hardware tools
Ask questions and find answers on STM32 hardware set-ups, including schematic-related challenges, debugging probes, power configurations, and more.
Nucleo-H753ZI connection error
I am a beginner at stm32 Nucleo board, when I connect the board and the Lap, LD5 turns green but LD4 turns to green/red blinking, which means the voltage is correct but the MCU has no response or connection error. Could you please help with that?
DeMar by Associate II
  • 1413 Views
  • 7 replies
  • 2 kudos
STM32F411 USB Boot Issuee
Hello, I have been having issues trying to get my STM32F411 PCB working with the USB-C bootloader, currently the device is not even being recognized at all by my computer. When checking with a multimeter I have found that D+ is not pulled high by the...
esb8 by Associate
  • 487 Views
  • 0 replies
Two board I2C communication
Iam Using 2 STM32F407VGT6 board one as master and another board as slave from Master side it is Transmitting but slave is showing the Bus error both Master and slave iam using in the inturrept mode
Adi3 by Associate
  • 993 Views
  • 4 replies
  • 2 kudos
Resolved! LDO Power Supply for STM32H757A
Hello everyone,I've noticed that several users have experienced issues related to the LDO power supply setup for the STM32H757A. I’m currently working on a design using this MCU in LDO mode, and I’d like to confirm whether my power supply implementat...
Ronil by Senior
  • 574 Views
  • 4 replies
Resolved! Blink User LED on Nucleo-F439ZI
I want to let the user LEDs blinken, however it is not working. When I run the code the LD4(COM) is blinking red and green. after the run the LD4(COM) is red the whole time and the user LEDs do not blink. Should the LD4(COM) be lighting green?
ap44 by Associate II
  • 2078 Views
  • 11 replies
  • 6 kudos
