2024-12-30 8:45 PM
I am using the STM32L476RET6TR MCU. Please suggest SMD-type crystals for both HSC and LSC.
2024-12-30 11:15 PM
Welcome @yashvant, to the community!
You will find recommendations and hints to select your favourite one in the application note AN2867.
Hope that helps?
Peter
2024-12-31 8:29 PM
Thank you, Peter Bensch, for your reply to my question.
However, I am looking for an HSC in STM32L476RET6TR. In this model, the HSC is an 8 MHz through-hole component, but I would prefer to use an SMD version instead.
please give your suggestion to me
2025-01-01 4:11 AM
Most distributors have nice search facility. Search and find suggestions there. Probaly nobody will do this work for you until your give us a very good reason why we should do the work for you.
2025-01-01 7:22 AM
Pull the Data Sheets for the oscillator, find equivalent parts in the SMT form-factor, perhaps from the same vendor
If you need to copy/cut-n-paste a design, perhaps look at other L4 NUCLEO/DISCO/EVAL board designs. Schematics and BoM can usually be found under the "CAD Resources" tab on the various product home pages.
Perhaps confer with your collegues or supervisors with more familiarity wih crystals, capacitance, and circuit layout of the PCB for optimal topology/placement
