2024-12-31 2:31 AM
i am using stm32u575zi-q board as master and ads131m04 board as slave for the spi communication.
i need ads131m04.h and ads131m04.c files specific to stm32 board .
2025-01-02 11:16 PM
ST usualy provide drivers only for her components or for others. For that you should contact Even the owner of this component or try to implement your own. As i Said before, m’y collegues will contact you in Privet for more infos if possible.
Best Regards.
STTwo-32
2024-12-31 2:53 AM
Hello @hybrid and welcome to the ST Community.
The ads131m04 is not an ST component. So, i suggest you to contact the owner of this component or take a look at some github repositories that may can give you the driver you are looking for (not ST tested). Also, i’ve escalted your request to our online support and they Will contact you (maybe with some delay due to the holidays). They may have something internal that they can share with you.
Best Regards.
STTwo-32
2024-12-31 6:28 AM
Hi @hybrid
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Billy
2025-01-02 8:55 PM
i have gone through the repositories but for this board(ads131m04) i was not able to get any drivers. specific to stm32 boards.
2025-01-02 11:16 PM
Best Regards.
STTwo-32
